way2roll wrote:
I stopped using the auto level feature. It seems like it would make it way more complicated than it needed to be. Like a Rube Goldberg machine. Twisting and creaking the MH, back and forth, up and down and eventually level but in a way that made no sense often with one or more of the wheels off the ground. Almost like it was continually compensating for itself. I manually level and it's so much easier and simple and I can do it in 1/4 the time. I have level bubbles in the MH but more often than not, a lot of MH surfaces aren't parallel. Like the countertop and the table and the floor are all just a tad bit off. I use the level on my smart phone in various spots and take the median. We also have a large slide and I tend to favor that side a hair higher as I know after a day or so that side will settle down an inch or so because of the weight. I don't stress over it, it's a MH usually on a non level surface with tires and suspension that will settle and move a bit, so I get it as close as I can and move on to other things.
I also only manually level. Seems to put way less stress on the motorhome. My auto level also seems to bring up the motorhome higher than is necessary. Many times it brings the front wheels off the ground.
