Aug-13-2015 04:21 PM
Aug-17-2015 03:32 PM
Arnie.G wrote:Awesome you found it, and quickly too!
Thanks everyone! I crawled under and looked for any wires connected to the chassis this morning. The second one I found and wiggled fixed the problem. Now I just have to clean it up and fix it permanently. But it sure feels good to know exactly where the problem is.
Aug-17-2015 01:39 PM
Aug-14-2015 07:16 AM
Aug-14-2015 07:04 AM
j-d wrote:That is what immediately popped into my head.....one or more corroded ground connections. Corroded chassis ground connections is a very common problem in older rigs....even newer rigs that are driven in winter where salt spray messes them up.
Watch out for weak and failed GROUND connections. Your batteries (chassis and house) should be securely grounded to the coach chassis. Your house wiring should be grounded back to the chassis too. If ground isn't solid, a light you turn on can try to "find" a ground through another light. That light may in turn light, or glow.
Aug-14-2015 07:01 AM
Aug-13-2015 07:33 PM
Aug-13-2015 05:43 PM
Aug-13-2015 05:14 PM
Aug-13-2015 04:30 PM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
