SageCrispin's avatar
SageCrispin
Lippert jacks Damon Challenger junction location
Hi all,
We have a Lippert hydraulic jack system which seems to be unique to the Damon line. It has been intermittent over the years. Right now I am trying to find the junction box or panel that is shown in the wiring diagram. The dash control panel cable and the pump/valve harnesses come together at that panel, but darned if I can find it. It looks like I am going to have to pull my dash to trace the wires, but I didn't know if anyone knew for sure where that junction is located. Thanks.
  • I forgot about that sensor. Mine is quite far forward of center, on the roof of a compartment as you said. Will look there for cable terminations. Thanks!
  • wa8yxm's avatar
    wa8yxm
    Ok the Power Gear system I have is.. I think the same as what you have (Power gear sold out to LCI)
    The system consists of 4.4 modules
    1: the panel inside the RV with the buttons. most of the electronics is here as well
    2: THe level sensor. Take a piece of string and tie it to the right front jack. then run it under the RV to the left rear jack. Do the same with the left front and right rear (With a 2nd piece of string or just loope it around the rear and bring it back to the other side front
    X marks the spot. Look above the X.. in my case it is in a basement compartment almost exactly above where those strings will cross.. ON the "Ceiling" of the compartment and next to impossible to get to.
    Module 3 is the pump/valve assembly
    Modules 4 are the jacks. (4.1.2.3.4)
