Looking for shop in San Diego for TV/audio/ help
supercub
I'm going to be in Santee Lakes near San Diego next week. I'm looking for a good tech that can get all my TV audio systems working. I have Sat TV and it works fine, but can't get it to work on the exterior antenna or the cable feed. I have a switch box, surround sound, dvd player, etc, the typical stuff. Looking for someone that is electronic savy as far as hooking everything up, or checking to see if cables, wires are all plugged into correct spots. Thanks
Brian
4 REPLIES 4
Not_a_Clue
Brian
check with Santee when you check in....the flyer they give you also has some ads for services in the area.
Have fun love that campground.
Linda B.
Our Blog
2009 29' Fleetwood, Fiesta V10 - The Little Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
FMCA# F412985
Traveling with Robin(friend)& Buddee(cavalier)
hmarashi
If you need to go see an rv shop, there is one nearby in Lakeside called Webb.
edbehnke
here you go...start calling
https://www.google.com.mx/search?q=san+diego+tv+service+surround+sound+systems&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&channel=sb&gfe_rd=cr&ei=-LmAVOSLGMnE8gfL6IHICw
as for you sat running to your box/tv from outside connector, make sure your antenna amp. switch is off.
eddie and sandie
3402 Montana 2013
Ford F350 2015
Humpty
I am not an expert and not in the area, but typically the SAT feed is direct from the dish to the receiver. It needs to bypass all switch boxes, etc.
I have a SAT In line that runs to my entertainment center. I have a separate In line that is for Park Cable of Antenna. I have to change input lines by removing and replacing the cables.
2007 Challenger 33DBB parked on the Coast
2016 GMC Canyon Diesel
