Seabass69's avatar
Seabass69
Looking to buy, ALADIN?
Im going to look at a coach tomorrow and was told the Aladdin system doesn't work. What does it do and should I be concerned? or can it be repaired reasonably maybe? Thanks. 2005 Monaco Dynasty
  • If anyone knows of a sourse for an Aladdin joystick I would appreciate a hint on where to look. Thanks. dreamer.
  • The Aladdin system is an information system that provides a lot of info about your RV. They can be replaced by the Silverleaf system. There is a lot of info about both systems and the switchout over at iRV2 forum. Rather than try to tell you everything it does, incl your camera system, I've attached a link to the user manual in pdf form. It will show you everything it offers....hope you have some savings if you need to replace/repair it. Could be expensive, or not depending on why it doesn't work......Dennis
    Aladdin System User Guide
