retiredhfd's avatar
retiredhfd
Lost power on wiper blades,air horn,cruise control
My Nieghbor has a 2005 Winnabego Journey and he has lost power to air horn, wiper blades,and cruise control. We have checked the fuses and all seem ok. Any help would b appreciated.
Thanks
  • Could be a connection in the steering column. thats the only thing that is common to all three if the wipers are on the turn signal arm. Look for a pinched or broken wire.
  • some times fuse holders get a little oxidation on them and the fuse itself clean them up a bit, I,ve used a contact clean and it worked ,but a bit of steel wool is better watch that you only touch one side at a time of the fuse mount.
