pwrchrd's avatar
pwrchrd
Low clearance pulling a trailer
Greetings,
2nd outing this weekend uncovered a few problems.
The rear end of our 2006 26' class C Winnebago Outlook seems to nearly hit the ground if I go over any large humps, like those entering and existing some gas stations. I have the air bags at 80 psi (max is 100 psi but concerned setting anything to max levels). I was loaded with fresh water which I suspect didn't help. I pull a small, ( < 1000 lb Rzr trailer), and the tongue jack sand pad hit the road and is destroyed. Other than switching from a A-frame jack to a side mounted flip jack to increase my trailer tongue clearance what are my options?
Kurt
