I have a 91 Beaver motorhome and cannot get any of the LP appliances to work. Generator is also LP and works just fine. Turned the vapor valve on and off number of times. Disconncted the regulator ...
There may be a electric shut off vale in the propane line. Going into the inside of the coach. They are usually connected to the gas detector in the coach. Is it turned on?
