- diplomatdonExplorerWhy worry about it until you next want to use it, stop b a tire shop that does trucks, and have them install the right one. There are several different styles used, and you want the proper one. Also when installed it will need to be torqued. Luck, Don
- Take one off and take it to your local NAPA Store or big rig repair shop and see if they can match it up for you.
- gutfeltExplorer
deandec wrote:
What size lug nut do I need for my Gillig Bus wheel?
22.5 x 7.5 Alcoa wheel.
you need to look at one and measure the stud width and is it tapered or flat
About Motorhome Group
38,707 PostsLatest Activity: Jan 05, 2014
