Master Cylinder??
MandJ_01
Help does any know where to get a brake master cylinder for a 89 Southwind? Mine leaks from bottom where it bolts to the power booster.
14 REPLIES 14
MandJ_01
thanks guys I did find one I picked it up today for $76 I use a 88 Ford F700
RLS7201
MandJ_01 wrote:
RLS7201 wrote:
Is your 89 Southwind on a Ford F53 chassis or an Oshkosh chassis? Both used the Ford 460.
Richard
Not sure but Im going to run the vin. I think I found one under a 89 ford F700 it looks exactly like the one I have from the pictures in O'Riley,I pick it up tomorrow.
F53 has EFI & 4 speed E4OD over drive tranny. Oshkosh has a carb & 3 speed C6 tranny.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
MandJ_01
Richard
mlslcan
I think the Southwind is on the John Deere (Oshkosh, later bought by Freightliner) chassis. If so here is a link to a parts book. http://jdpc.deere.com/jdpc/pdfs/PC2109.pdf
Freightliner used to be able to look up parts and had them. It has been a few years since my friend sold his JD based rv so I am not sure if they still help or not.
Mike
darsben
I repeat because it bears repeating.
Having a 1989 Southwind MOST LIKELY means it is on a 1988 chassis.
It is common for Motor home builders to buy a lot of chassis' ahead of production. IN order to ensure they have them for the start of their model year.
Fleetwood WILL HELP YOU determine the year of the chassis.
The 1989 year is the year assigned by Fleetwood to the completed unit.
Traveling with my best friend my wife!
RLS7201
Richard
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
MountainAir05
MandJ_01 wrote:
MountainAir05 wrote:
Autozone show it, plus online Rockauto, so you should be able to find it local.
would also suggest to get new or a kit, due to a new one comes with a new container for the brake fluid. Rebuild come without.
didnt find it on their website do you know how to look it up?
Year 1989 Ford F53 Brake Master cylinder
You will have to look at the vin to be sure on the year.
darsben
I looked up 1988 ford F53 on Rock auto and found one. Is it yours? I do not know becuse I do not know which ford chassis your southwind is on..
BTW if your Southwind is an 1989 it is MOST LIKELY on a 1988 chassis
MandJ_01
Jagtech
Couldn't you have a local auto machine shop just rebuild it?
1998 Triple E F53
1995 Jeep Wrangler toad
MountainAir05
MandJ_01
Would help to know if Ford/Chevy chassis. Sound like rebuild or replace it.
Do you where I can find ethither one?
MandJ_01
Ford 460
MountainAir05
