BillHoughton's avatar
BillHoughton
Jun 27, 2015
Mercedes/Sprinter (2007) dash message - ?
This may be a dealer question, but I thought I'd ask in this knowledgeable community.
Our 2007 Itasca is built on a Dodge Sprinter (Mercedes-built) chassis. We went up into the foothills this last week, and were running the air conditioning because it was hot. The water temperature gauge, which normally hovers around 180 degrees, crept up to the next increment, which is unmarked but appears to be about 215 degrees. Suddenly, the little screen below the speedometer that Mercedes calls the "Multi-function Indicator" (odometer, trip meter, clock, outside temp, other stuff) started flashing "HI," with a little arrow above it, with an accompanying beep. We turned off the air, and I slowed down a bit, and it soon stopped.
But then, on the way home, it repeated, while the water temperature was below that mark, at a temp that we'd reached before, with no frantic signals from the dash.
Our son, more knowledgeable in diesels than we are, thinks it might have been communicating that the exhaust temperature was too high, something can be a serious problem, and that the cure is to let off the throttle a bit.
The owner's manual says nothing whatsoever on the subject.
Help!
  • The Hi warning light came on my 2006 Sprinter right after I had a dealership change the oil. Evidently the sensor is VERY sensitive and it doesn't take much to trigger the alarm. A small amount was drained off and all was fine again.
  • yes synthic oil expands, and if the last guy that changed the oil over filled it ,it will set off a alarm, mine has two marks on the dip stick. and I keep it in the middle of the two ,when checking it COLD. is yours the V^ or 5 cyc?
  • Thanks. These posts directed me back to the owner's manual, where, yes, there's a brief little mention of the "hi" message. It says, "don't operate the vehicle when this message displays." Ooops. This thread motivated me finally to look at the service receipts given us by the previous owners, who told us they'd had the oil changed six months before we bought it. Turns out it was a year before we bought it, and it's now overdue for an oil change.
    We haven't had occasion to put any oil in since we bought it, and the dipstick has shown as just fine.
    What would cause oil level to be too high, other than a mistake by the shop doing the work? Does diesel leak down from the combustion chamber into the oil? Does the oil expand when it's warm, and moreso when it gets good and hot?
  • There is a specific procedure on mine for checking the oil level. Fully warmed up engine and then let it sit for 5 minutes or so. On mine I can check it form the dash. Overfilling a diesel engine is bad juju.
  • I just googled it and it says high oil level. by the dealer,, never check oil till its good and hot ,the oil expanse a lot , and at cold it looks low. I typed in sprinter HI message on google.
  • we have the I 5 engine my temp gauge moves around a bit but never over 200 mark, like the other post said more info needed. only time I got a message is the time I added to much oil. I,d stop and have your codes read . ain,t it great getting 20 mpg.
  • Maybe you could provide some background.
    Which engine do you have?
    How many miles on your rig?
    Is it gas or diesel?
    When was the last time you changed oil, coolant, etc.
    Have you had the exhaust system serviced? Such as a Diesel Particulater Filter (DPF).
    Does your rig use Diesel Exhaust Fluid (DEF)?
    Does your engine have a Turbocharger? (Suspect perhaps a cracked manifold).
