Dirtyrhoades77's avatar
Mar 05, 2021
Mini-split in compartment
Hi all, I'm in the planning stages of a Class C boondocker, loaded with solar panels, a big 24v battery, all that.
I'd like to install a mini-split up near the front of the vehicle, so when the sun is up and the heat is on, the living area is cool. I'm planning on a 9000btu unit as I think that would be enough if the roof is covered in panels providing some shielding from direct sun. I'd like to cram the external unit into a compartment nearby so it's close to the head unit, and on the driver's side so it's not disrupting the awning space on the passenger side. I'd have the fan exhaust blowing straight out the side, cutting a hole in the panel door for it.
The exterior unit's dimensions are in inches 32w*22h*14d.
Assuming I'm willing and able to remove the generator or propane if necessary, or modify whatever other type of compartment is in that area, are those compartments big enough to accommodate those dimensions?
I imagine the height is the biggest problem, it would hang down a bit. I'd have to bolt or weld in a frame for it to sit on, preferring to keep the rubber grommet to sit on to absorb some of the vibration.
Does that sound doable? I'd much rather make this work than do a bedroom/bumper mount.
