Minnie Winnie 31G Water in Compartment
4gone
I have a 2018 Minnie Winnie 31g. I have had an issue with water accumulating in one of the storage compartments. It is the driver's side in front of the rear wheels. Another 31g owner contacted me with the same issue, however I am not sure if it's the same compartment. I can't find anything obvious to see where it's originating from. There was also moisture at the top of the compartment as if it was raining down condensation. It happened in both hot and cold weather so I suspect the water that's getting in is causing the condensation problem. Has anyone else with a similar Minnie Winnie have and issue like this and were you able to track it down?
2018 Winnebago Minnie Winnie 31G
2010 Suzuki Grand Vitara
Even Brake
Firestone air bags
Blue Ox Alladin tow bar
Hankook Tires
7 REPLIES 7
pauldub
CaptR, you really need to start a new thread for your problem.
To the OP, on my 2003 Winnie the outside compartment leak was through the screws that are in the sill of the door frame. I took the screws out and coated the threads with caulk and put them back in. I also sealed between the compartment liner and sidewall like Dusty R mentioned. I needed both fixes to stop the water intrusion.
CaptR
Hi all, along the same lines in front of my driver side wheel is the shower which leaks like a sieve... pan where meets walls has been caulked in past, brittle no doubt original from 2000, 30' fourwinds, majestic- identical example can be seen in this sales video... 3/4 toward the end:
https://m.youtube.com/watch?v=AU3Z_TVPgHM
Floor is spongy but in intact. Is it possible to replace the floor up 3 or 4"'s where all the cracks/ing is to avoid messing with the walls and plumbing? Alternatively, is there a miracle wide rubbery waterproof tape for a quick fix?
Very best, R
bobndot
I took a brass hammer and carefully banged the aluminum lip that the bulb seal was attached to, outward, so it contacted the door better.
great idea . You didn't have order or replace a part. tap tap tap and you're back in business. :C
SidecarFlip
I had the same issue with a side compartment on my TC, it was getting water in it when driving in the rain.
After taking a hard look at the sealing lip I discovered the door was not compressing the bulb seal all the way around, so I took a brass hammer and carefully banged the aluminum lip that the bulb seal was attached to, outward, so it contacted the door better. No more water in the compartment. Takes a little trial and error time but doable.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
bobndot
Is it an empty compartment that floods ? Or is there plumbing in it ?
Is the water fill above it ?
If so, those fill hoses can loosen up and water could leak into a nearby compartment.
Here is a thread for more info.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22581750/print/true.cfm
Dusty_R
We have a '15 Itasca Spirt 27Q. It has 3 outside storage compartments on the right side that leaked when driving in rain. The dealer put new gaskets on the doors and like I figured that didn't fix the leaks. I used black roofing mastic, tar type caulking, and resealed the compartment seams from the outside, under the mh. that fixed my problem, it did take a couple of times.
Dusty
MobileBasset
I had that happen one time when I parked it overnight with the compartment in the path of a rotor sprinkler head.
MobileBasset
2014 Itasca Spirit 25B on Chevy Express 3500 chassis
Daisy and Hank the Basset Hounds
