Vulcan_Rider's avatar
Vulcan_Rider
Moisture in headlights: E450
Is this a common problem ?
It looks like both of mine have a crack in the bottom; almost identical. Since it's the bottom, I didn't thing it would cause a problem.....but something is letting in moisture; a little in one and a LOT in the other.
Are they hard to change out ?? I haven't looked yet.
  • Can't speak directly to the E450, but the F250 and F350 are easy to change, just not the cheapest. On the F truck you have to loosen up the four screws on top of the grill cover so it will move out of the way slightly to get the light out. You might check the local junk yard to compare with a new price.
    Bill
