Mopping up toilet water at 3 am!
Tedtoo
I have a Thetford Aqua Magic Style II toilet. Two nights ago, when I visited it, there was water all over the bathroom floor and the toilet bowl was completely full. It had obviously overflowed. When I depressed the pedal, it burped at me and the water went down. After the cleanup, I assumed that the ball had not completely closed and that caused the water to continue to run into the bowl. So yesterday, I cleaned all around the ball, removing any calcium deposits. Well, the toilet gremlin struck again last night at 3 am! This time I was careful to look at the ball and it was completely closed, but the toilet bowl was full of water and overflowing.
Before tonight, what should I look for? I have a call in to a repairman, but he can't come for at least two days. I will turn off the outside water and turn the pump off and on as needed, but thought someone could steer me to the cause of this!
10 REPLIES 10
garry1p
X2 on the water shut off valve.
Don't know why they don't install them when installing the toilet.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
Bruce_Brown
Moderator
Moderator
bgum wrote:
I would try a new different branded toilet.
Most of them use the same valve, so I'm not sure you'd gain much.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
WILDEBILL308
Had the same problem. Wouldn't you know it one of the few times the toilet slide valve didn't leak down. It is simple just pull the valve and take it with you to be shore you get the right one. Takes about 15 minuets to change.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
N7SJN
Ours was a low water pressure issue. Wound up by replacing toilet.
bgum
Bruce_Brown
Moderator
Moderator
I replaced ours for the same reason a few years ago. Easy job and the parts weren't that expensive either.
Ours was on a regulator at the time, it just decided it was going to ever-so-slightly leak through.
Bruce & Jill Brown
newman_fulltime
if you do not have a water regulator they will leak through
robertbenita
Water valve would likely be your issue. Not too difficult to do yourself and videos on internet. I did it at same time replaced gasket and flapper silicone thingy that seals ball. Good luck!
It might actually be called a regulator???
Old-Biscuit
Ball only keeps water in bowl Or lets it dump
Water valve is leaking thru.
Need to buy new water valve assembly and change it out
In mean time..turn off water supply until you need to use it.
When you replace water valve assembly.install a shutoff valve at same time so that you can isolate toilet separately in the future
naturist
Don't have that exact model, but have had the same problem. Wife got up in the wee hours, and in order to keep the racket down so she wouldn't wake me up, she gently closed the flipper and the flush-thing. In the morning, what a mess, water everywhere.
We concluded that there was a reason the flush mechanism was designed to pull the lever and let it snap back into place. It has never happened again. The rule now is "Snap closed with vigor!"
