sempka's avatar
sempka
Motor runs hot when rpm increase
2000 Holiday Rambler with a 2000 Ford Triton V-10 motor, motor started to run hot when going up hill and the transmission downshifted causing rpm to increase. Replaced the a bad fan clutch the thermostat and had the radiator flushed, drove it about 500 miles and motor started to run hot when rpm increased, replaced the thermostat again based on recommendation from a mechanic. Drove motorhome about 900 miles before problem reoccurred after running about 3 hours that day the motor started to run hot again when the rpm increased going up a hill. I never let the motor get hot enough to get out of the operating range, by slowing down and letting the rpm drop. Any suggestions on where to look next?
