Executive45
Jul 06, 2013Explorer III
Dave, try this...get yourself a small A/C fan, something like the Honeywell turbo fan from WalMart..you probably have one around the house...remove the outside fridge access door and bungee cord the fan so the air is blowing up across the cooling unit. Turn your fridge on and see how quickly it cools down. If you see no change, then perhaps you don't need the fans. If you do, this is a cheap fix..and it looks much better than the fan and bungee cord...:B....Dennis
Why do we need fans when we didn't before?
There's a number of reasons...your fridge is bigger than the one your parents had...there's also the fact that the coolant we used before cannot be used today..remember freon in your automobile's A/C...??? cleaner healthier air means changes...Dennis
38,764 PostsLatest Activity: Dec 23, 2025
