rgnprof's avatar
rgnprof
My Ford E350 running a bit hotter
I recently had one of my cylinder heads rebuilt and a new exhaust manifold installed, as well as a new radiator and thermostat - just got back from a trip to Colorado and there were several occasions when the MH temp gauge got up to the A and almost to the L (In NORMAL)...prior to this I don't remember the gauge ever going above R.
I was towing a Subaru and we had no troubles, except for this concern...it seemed to me that this was more related to transmission heat, which was confirmed when I started backing the coach into our driveway. It is a bit of an incline, in reverse, into our driveway and it started leaking tranny fluid from the bell housing plug. Pretty good leak, that stopped after I shut off the motor. Pulled the plug and started it up again in 20-30 minutes and no leak at all.
I'm thinking the transmission was running hotter than normal, and the front seal started leaking - probably even more pushed by the Reverse up the incline.
I'm trying to figure out a way to add a transmission cooler - lots of options and opinions...Any thoughts? I've checked out Tru-Cool, B&M, Hayden...also thinking about replacing the fan clutch...also, do you remove the existing cooler that is on the L side of the AC condenser (I guess it's stock)...
Thanks, ryan
I know I may have to replace the front seal, but I thought I might try to change the fluid/filter (BTW, the fluid is nice and red and doesn't smell burnt at all), install the cooler and see what happens first...
