awolsmith's avatar
awolsmith
National Air Bag question
I recently purchased a pre-owned 2002 National Tradewinds LE. I have several switches not mentioned in any manual. The 2 aux switches on the driver dashboard one on the right and one on the left. Anybody have a similar model that has figured out what they do? Also the radio switch says Stereo TV or something like that, I can look at it later to verify. Anybody have that 3 way switch and figured out why up is on middle is off, down is on again.
  • There is already a battery disconnect near the steps and I have fan, map lights, generator on/off also. I will try and take a picture and post it here.
  • If the switch returns to the center position, they are called momemtary switches. They are used for different functions.
    It could be for battery disconnects
    Or Auxilary start funcrion which ties the coach and chassis batteries together for extra startin.
    Could be for the start and stop functions of the genset.
    Is there any pictures adjacent to the switches or inside the switch it self?
  • I have a National Tropical and without looking at the dash I can't tell you what everything is for. I can tell you I don't have any switches that don't control something. A possibility is I have two separate toggle switches that control the auto visors on the passenger and drivers side and a toggle switch for the fans above the windshield. I also have a toggle switch for a reading lamp above the drivers seat. So if your motorhome doesn't have any of those items, that may be what the switches were intended for. They are going to install the switch whether you have the item installed or not. I don't recall any switches labeled as "Aux" so my guess is they are just extra for things you may want to add.
