National Sea Breeze bedroom slide gears
desertrver
2004 National Sea Breeze bedroom slide gears chewed up. Has a Von Weise motor which is fine. I’ve been searching for replacement. Does not seem to be replacement gear assembly available that I’ve found. Mine is a small black box attached to the motor at 90 deg. I’ve seen where there have been replacement motor assembly connected directly to rail. Not using the gear assembly.
I would appreciate any assistance in locating the upgraded slide assembly.
6 REPLIES 6
RLS7201
If GREGORYJ has the correct information for you, then Boston Gear has a better price.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
GREGORYJ
Does it look like this slide out gear/motor assembly used in the 05 Dolphin.
If so, I had problems with the brass gear losing teeth. I tried a steal replacement gear but is too brittle and also broke. The gear needed was a Martin WB1220 that requires the bore to be drilled out from 1/2" to 5/8" and a 1/4" hole drilled for the roll pin. I found replacement gears in brass or steal but that was 4 to 5 years ago now, I see they are still listed.
https://www.motioncanada.ca/productDetail.jsp?sku=00367424
Ellen & Greg
08 National Dolphin DL-35Ci, Kelderman Air Ride, Rear Trac Bar
Workhorse W22, RoadMaster Rear Sway Bar, Towing 08 Smart Car
desertrver
Follow up on bedroom slide out issue. I was able to find the replacement motor assembly. It is a RBW upgrade that was replacing the old units when National was still in business. I found and contacted Temecula Valley RV. They have access to the upgrade. Not cheep! But, it appears to be the only parts out there. Only other option is to rebuild the small black gear box. I think some have done that. Thanks to this group, a great resource.
desertrver
Thanks, I’ve been there. I’ve contacted Weise directly. All kinds of motor assemblies. Nothing that will work for my application.
As I said, I’ve seen pictures of an upgrade for the Sea Breeze bedroom that doesn’t have the gearbox. It’s a complete different motor assembly. I’m hoping someone might be familiar with the updated assembly and a source. I’ll find the pictures and post
garym114
Is it a Power Gear?
Model of RV makes no difference, just the model of the slide.
2000 Sea Breeze F53 V10 - CR-V Toad
Some RV batteries live a long and useful life, some are murdered.
Get a Digital Multimeter and Learn How to Use It
ScottG
I googled "Von Weise 12V motor gear set" and got all kinds of hits.
Might try that.
Good luck!
Scott
