wborst wrote:
I recently bought a 2003 Newmar Mountain Aire 4097. I can't find a way to dump the fresh water tank except turning on the pump and opening the outside shower valves. Is there a gravity dump valve for the fresh water tank? If so, where would I find it.
Also, I have read that I should open the air tank drains to expel any water they may hold. Where are the air tanks located and are these valves reachable without crawling under the coach?
Thanks for any help you can provide.
Bill
Call Newmar at their 1-800- number with the last 5 of the vin. they will know
