reddfox77
Nov 03, 2014Explorer
NEED Help from the experts
This is the only place I can get real help...I have a 1993 Georgie Boy Swinger...Need a few parts and dont know where to turn..Trim above the wheel well drivers side front and parts for wipers ..its the gadget under the hood that connects to the hose for fluid...Also have a repair question...I have two antennas on top of the coach one that is not being used and hits every tree branch possible...it has caused the screws to come loose and made the rubber roof tear slightly around the base...I removed the antenna and the mounting base is still there...I tried putting eternabond tape and then coating it with dicore...tape wont stick for some reason..any way Im wanting to just removed the base and seal it..What is the best way to do this? Thanks so much guys your all top notch...
