โJun-24-2014 10:18 AM
โJun-26-2014 12:02 PM
โJun-25-2014 12:38 PM
โJun-25-2014 12:33 PM
โJun-25-2014 12:31 PM
goufgators wrote:Tom N wrote:
I own a 2005 Itasca Suncruiser.
Your TVs are powered through your inverter.
Check the breaker on you inverter in the cabinet above the passenger seat.
-Tom
Thanks, Tom! I was looking at that breaker yesterday and thinking I should check it. Will do today. I'll let you know.../ Larry
โJun-25-2014 02:46 AM
-Tom
โJun-24-2014 12:18 PM
โJun-24-2014 11:49 AM
tommy g wrote:Same here. The relay works off of 12VDC power from the ignition switch circuits. If you have one of THESE you can test if the AC line to the outlets are hot. Also with one of THESE to check if you have DC power to operate the lock out relay.kdk wrote:I agree!
,,, also most MH will disable the power to the TV's when the ignition switch is on. On my MH this relay is mounted adjacent to the TV receptical.
Blessings KDK
โJun-24-2014 11:39 AM
โJun-24-2014 11:28 AM
kdk wrote:I agree!
Don't know what type inverter you have but most have resettable circuit breakers that control separate circuits. Check them and also most MH will disable the power to the TV's when the ignition switch is on. On my MH this relay is mounted adjacent to the TV receptical.
Blessings KDK
โJun-24-2014 10:56 AM
sch911 wrote:
Were these added special after the fact?
โJun-24-2014 10:47 AM
goufgators wrote:Bumpyroad wrote:
are any of these GFI outlets/circuits
bumpy
Bumpy: Good thought but no they are not GFI.
โJun-24-2014 10:34 AM
โJun-24-2014 10:33 AM
bumpy
โJun-24-2014 10:32 AM
