midnightsadie
Oct 10, 2014Explorer II
need propane help,
on my 2007 leisure travel van freedom II my bleed off valve won,t bleed off when filling the tank. drained propane to empty ,, took bleeder out I could blow thru it with ease, not clogged,, took to propane fill dealer ,gave it a short blast of qas tried bleeder,no work, its clogged, smashed or some ,, but to get under this rv you gotta be a real skinny person, any other idea,s even blew the air hose backwards into the bleeder line. it appears this assembly was installed before the poo tank was installed. so to really get to the fittings the poo tank has to come out. from what I can see.
