pauly_boy's avatar
pauly_boy
No power from house batterys
I'm fine with shore power but I don't seem to be getting any power from the house battery's(2). Was working. Any idea's.
Thanks Paul
  • Hey what is this, the RV Net version of ‘I’ve Got A Secret ? ??
  • x 2!!! This website helps everyone by posting a problem/situation and FINDING A SOLUTION!
  • pauly boy wrote:
    Problem solved. Motoring west next week. Ya Who
    What was the solution? Reporting back can help others.
    Thanks Paul
    Do you have a generator and is that supplying house power.
  • If the switch is on then i would ,
    Remove the cables to the battery and check the voltage. 12.6 - 12.8 range would be a fully charged battery.
    If there is no 12v power once you replace the cables, i would check the fuses and make sure the ground connection off the neg battery terminal to the chassis ground is clean.
