Cheryl_B
Nov 01, 2017Explorer
Norcold 962 fridge giving error code; dc voltage too high
Here I am in a campground, finally able to plug in my rig and enjoy the relaxation that comes from shore power and all the other niceties. I get an A8 code. I look it up and it says the dc voltage is too high. I check the converter and fuses (cause I read that it could be a bad converter) and couldn't see anything wrong.
The light in the fridge wouldn't come on although the display was still visible on the door and it wasn't beeping at all, just showing that A8. But I started noticing the temperature slowing beginning to rise and it was getting into the upper 40's, so I unplugged from shore power, went back on LP and she's fine again.
Well, I want to plug the dog gone thing back in. I'm paying for this electricity and these comforts, so if you can help me to figure out what could be causing this, I will try whatever you say. I have researched and done my homework and even sent an email to the "norcold guy". Waiting for his response.
Got the power turned off at the pole and got the temp turned all the way down on the fridge to get it as cold as I can get it before I plug back in, a few hours from now. I will need the power to run the furnace. I'll have to shut the fridge off for the night and just keep the doors closed.
Is this really "living the dream"? Or is it just me?
