richard_123's avatar
richard_123
norcold ref
have single door norcold ref., had unit turned off for 2 weeks while dealer did some body paint. Upon returning turned ref on, freezer got cold and began making ice. the ref is not getting cold after 6 hours. well maybe a little. have temp set a 8. suggestions.
  • When I turn my fridge on after being off I stick a couple of Blue Ice blocks in the lower compartments to get it down to temp. in time to use.
  • I agree, 6 hours is just not enough time but you may already know that by now...
  • You may or may not have a problem. I would not check the refrigerator temperature for 24 hours after starting it. That the freezer is already making ice has no bearing. The cooling cycle for an absorption refrigerator starts at the freezer; i.e., the most cooling is there. Moreover, the freezer has a much smaller volume from which heat must be absorbed.
    If the empty refrigerator has not cooled 24 hours after starting, then I would become concerned. (Adding food to the refrigerator will lengthen the time required to reach an acceptable temperature.)
    Tom
