dougrainer
Jul 25, 2017Nomad
ichudov wrote:Jim@HiTek wrote:ichudov wrote:
Thanks guys for guiding me. I have replaced the spark wire yesterday. The sparks work GREAT and the flame starts every time.
However, despite that, flame is still NOT detected.
The "tower" on top of the control board, from where the spark electrode terminal comes out, is NOT loose.
I feel that I am making progress, eliminating possibilities at acceptable cost, but still no final resolution.
In that case, then you probably need to follow Doug Rainers instructions above. If you can solder and have the equipment that is...
Good luck!
You don't open it up. You remove the main board and look behind the board and re-solder the Piezo pins that are soldered. Doug
Thanks! I will try to see how I can open up that Piezo tower. I can solder no problem.
38,705 PostsLatest Activity: Jan 24, 2025
