May-29-2015 05:35 AM
May-30-2015 03:37 AM
May-29-2015 04:55 PM
May-29-2015 11:33 AM
Dennis M M wrote:
.... I installed an ARPrv system to prevent to problem before it occurs. Relatively easy installation if you are handy and works seamlessly.
May-29-2015 10:43 AM
DrewE wrote:
The recall should address the main safety concerns.
As I understand it, the problems had to deal with the metal fatiguing and cracking in the cooling unit due to excessive heating and cooling around the electric element (and possibly poor manufacture/materials). If a crack developed and the fridge was running on propane, the ammonia refrigerant under the wrong circumstances could be ignited and cause a bad fire. The recall fix prevents this by containing any fire and shutting off the propane if the temperature gets excessively high in the burner area.
The fridge should be reasonably level while running when not en route to ensure proper coolant circulation by gravity. (While driving, the movement of the vehicle helps keep things moving.) Generally speaking, if things are reasonably level for human use--if the shower drains properly and the cabinet doors don't all want to swing to the same angle and eggs stay in the middle of the frypan--then the fridge is more than sufficiently leveled.
May-29-2015 08:35 AM
May-29-2015 08:21 AM
May-29-2015 06:25 AM
May-29-2015 05:48 AM
