SPRING_STREET's avatar
Apr 04, 2018
OASIS ELECTRIC USAGE
I like using the electric setting on my oasis to heat the coach on furnace ! was wondering if this is more economical that using the diesel burner and the furnace setting ? cross posted
Thanks Dave
  • Hi,
    Not necessarily. Here is a web page that helps one choose. The place I winter camp doesn't meter the power, so it is definitely the cheapest way to heat:
    http://www.maxmcarter.com/fuels/fuelscalc.html
    SPRING STREET wrote:
    As far as electrical usage where does using the heat pumps come into play, I would assume that would be the most expensive ???
  • Why use fuel if you don't have to? I know electricity is a form of fuel, but at least it's a plug in and not something you need to go refill.
  • Ivylog's avatar
    Ivylog
    Heat pumps are the most efficient way to heat...3-4 times better than resistive electric. I use mine down to freezing where they are still 2X elect or 3X diesel. Put your hand close to the exhaust of your Oasis or AquaHot...that's wasted energy.
  • As far as electrical usage where does using the heat pumps come into play, I would assume that would be the most expensive ???
  • I use the diesel setting on my oasis if it’s 40 degrees or colder, otherwise I use the electric.
  • Heating the water with electricity is cheaper than using diesel and there are no fumes blowing into your neighbors patio area. Two pluses.
    Thanks Dave
    don't know about economical or not but whenever we have the chance I prefer not to use my consumables. we're currently in AZ and just got our electric bill for the 1st month...roughly $90 or $3/per day. might be high to some but we've been using electric heat at night and, lately, the AC during the day. our LP tank is still full.
