Oil change while on the road
two_travelers
We'll be taking an extended trip later this summer and will need to get an oil change on our gasser. I know Jiffy Lubes etc are out due to size and the Walmarts near us don't have bays big enough. Any suggestions as to where to go?
23 REPLIES 23
dcbrewer
I do mine at campground, lay down plastic to catch any thing that might splatter out, and grease while oil is draining. All done in about 20 min's.
roam1
I find it's faster and easier to do it myself. Get a 2-3 gal oil pan that seals, roll out a tarp to protect the area, change your oil, take the oid back to where you bought the new oil for recycle.
done it many times on the road
after paying $150 for an oil change on the road once, I decided to do it myself for about $40 and a little time, most times I can do it myself faster than driving to service center, checking in, waiting, driving back....
Dog_Trainer
Since you are a part of this community and forum, I would wait until the oil change was due then I would post here for suggestions for an oil change for a given location. I would think you would get a response from a fellow RVer.
2016 Newmar Baystar 3401
2011 HHR Toad
Daktari & Lydia Cavalier King Charles , Annie get your guns, our English setter (fur Bearing Children)
time2roll
camperguy99 wrote:
How long is the trip? Think the gas V10 can go 7-10K miles between oil changes? Do it before you leave and take an extra quart with you.
+1
Just keep it topped off until you get home.
wolfe10
Gjac wrote:
For trips shorter than 10k miles I just change before the trip. The longest trip I made was to Alaska and had to change the oil twice. Once was in a state park and asked if it was OK and my friend who has a DP and I just changed it there, very easy and quick on a class A gas much longer on his, but he is a full-timer and had a mechanics suit and set up to do it on the road. The second time was at boondock site just dropped the used oil of at a Walmart when are wive's shopped for food.
That is EXACTLY what we do. On the road, empty one of our Rubbermade storage containers, line it with two HD trash bags (so two layers of protection) and drain the diesel. Use an old coffee can to pour it into the jugs after filling the crankcase. Put the gallon jugs back in the case and take to Walmart.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Gjac
Bruce_Brown
Moderator
Moderator
^^^ This. Just do it before you leave.
A few years back I was pulling a TT across the country and back with my Super Duty. I knew the oil would need changing along the way and I knew it was something I didn't want to deal with. I had it changed locally before I left, problem solved.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
camperguy99
Mile_High
Interesting quandary!
In the gas vs diesel debate, one of the pros for gas is that anyone can work on them, whereas diesel is specialized. It would seem that when looking at a shop big enough to accept a motorhome, the gas engine is the foreigner.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
mtofell1
In preparation for buying a class A I was just looking into service options. You can search through Ford commercial service online and the various dealers list what type of equipment they can work on (class A, class C, F650, dump trucks, etc.). They also list the size/length of service bays and lift capacity. My take away was to either search this way or just call a dealer in an area I need service and I'd have to think if they can't help you the service writer would know a nearby dealer to send you to, if there is one.
2gypsies1
OP: It would help to create a Signature line which will automatically appear on your posts. Then folks know what kind/size RV you have.
However, I clicked on your Profile and if it's current you have a 29' Holiday Rambler Atlantis which I assume is a Class A. I believe some WalMarts would work if you gave them a call beforehand when you get into a new town.
Full-Timed for 16 Years
.... Back in S&B Again
Community Alumni
Not applicable
Most Ford dealers will do oil changes, especially if they sell commercial trucks and vans.
Dick_B
We had an oil change recently at Walmart.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Jim
It's always a good idea to put the particulars of your RV in your signature so people have a better idea of what kind of RV you are talking about.
Guessing you have a C, even though you posted in the Class A section, wherever you land for a few days, just do a google search for Truck Shops and call them. If they can do a semis oil change they can do yours.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
