dalefuji
Jul 28, 2023Explorer
Onan 5500 Generator in Holiday Rambler 1998 Endeavor
Generator runs sometimes and then shuts off.
Replaced with new:
Spark plugs, oil change, oil filter, air filter. "still no run"
Replaced:
New carburetor, New fuel pump, New fuel filter, No gas line hose from carburetor to fuel pump.
"still no luck"
The in line 10 amp fuse above stop/start switch is okay. The 20 amp
two blade fuse by breakers is okay.
I help "stop button" in for 15 seconds to prime Gen. and then hit start button and it started and ran for 60-90 seconds and then started getting rough and shut off and would not start.
I ordered new 5 blade relay plug under air intake to see if that is problem.
Are there any other in line fuses that could be problem
Any suggestions would be greatly appreciated.
Replaced with new:
Replaced:
"still no luck"
