Onan Gen Shuts Off
jmcgilvary
02 Fleetwood Bounder 36'
Onan 5KW
For some reason, of late, the Generator starts, carries a load (A/C's) but after 10-15 minutes, it shuts off.
No idea why.
Plenty of fuel, nothing has changed in the configuration in the last 3 years.
'Thoughts? Tips?
Thanks
24 REPLIES 24
LVJ58
SAR Tracker wrote:
Could still be fuel issue. Take a fuel suction from a can (bypassing the fuel tank, lines, and filter(s)), and see if it runs longer. If so, I'd bet on 15 year old fuel lines collapsing from age and ethanol fuels.
Good trouble shooting advice. Had the same problem with the genset in our 2000 coach, turned out to be cracks in fuel line from tank allowing air info the fuel line. Replaced fuel line and problem solved.
Good luck and let us know the fix.
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
gbopp
Don't forget to change your generator fuel filter. If the rubber lines are collapsing you may be pulling pieces of rubber into the filter.
If not, it's time to change the filter anyway. 🙂
jmcgilvary
Great, thanks, I can get the S/N no worries.
Today's project
1995brave
You need your generator serial number. You can either do a google search on the first part of the serial number or try the onan website, used to be www.onan.com, may have changed now.
jmcgilvary
OK, where would I find a schematic/idea on changing? I imagine something in my Bounder package might have it, if not WWW?
schwartzworld
I'm going to say it's the fuel pump. Unit heats up, the pump gets hot and stops pumping fuel. Fairly easy to replace.
jmcgilvary
OK, another great idea.
See, I LOVE this place!!
SAR_Tracker
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
jmcgilvary
OK, seems like a reasonable idea!
Thanks, I will as soon as I get home.
A1B00902
check the oil level
