May-28-2014 01:54 PM
May-29-2014 02:55 PM
May-29-2014 08:46 AM
May-29-2014 08:43 AM
May-29-2014 07:20 AM
May-29-2014 06:19 AM
Jim&Carolyn wrote:
I had/have the same exact issue on my Onan 2800 generator. I removed it and took it to the garage to a mechanic that says he repairs Onan generators and he says it needs a new voltage regulator and "ordered" one. That was 3 months ago and I still waiting for it to get fixed.
May-29-2014 05:38 AM
May-28-2014 08:51 PM
May-28-2014 08:11 PM
ROADTREKKER2000 wrote:
The amount of gas in the RV gas tank is criticle to operating the Onan generator.
When your RV gas tank gets below a quarter of a tank, the Onan will not run. This is a design feature to prevent the generator from using up all your RV gas.
'1775' made this point, but your response implies you didn't understand his comment.
May-28-2014 07:05 PM
May-28-2014 06:26 PM
May-28-2014 05:06 PM
May-28-2014 04:36 PM
Handbasket wrote:
You've got a failure to produce AC voltage. It's possibly the voltage regulator, the brushes, or the rotor-stator assembly.
The regulator is in the $250 range for parts (google 'Flight Systems'). It's a doable but dang fiddly DIY repair. There's a hidden Torx screw that's an utter bear to restart, with no lead-in to the hole and no tabs to locate the regulator.
IIRC, the Onan service manual takes you thru troubleshooting steps to isolate what the problem is. You'll need a volt-ohm meter & basic skills.
Jim, "Unapologetic flatulator."
May-28-2014 03:33 PM
1775 wrote:
Try starting the generator with the van engine running. Leave it running for a few minutes after the generator starts and stays running. I have found that if the Roadtrek batteries are low the generator will either not start at all or is hard starting. Make sure that there is nothing turned on inside the Roadtrek to take off all power loads when trying to start the generator and it is hard starting. Make sure the A/C switch is off, unplug the microwave. While this is not so much of a problem when all is well, when the generator is not starting this can be one of the problems. Also do you have more than a 1/4 tank of gas in the van? The generator will not start or run with less than a 1/4 tank.
Once you do get it started you may find that if you turn on a power load soon after starting it will stop again. Let it run for awhile before adding a power load - when it is hard to start.
May-28-2014 03:13 PM
