Bordercollie's avatar
Bordercollie
Onan Micro Quiet 4000 Gas Powered Generator Won't Crank
Has been starting and running for periodic exercise. Now tries, but won't crank, acts as if battery power is low. 13.1 volts at house battery with shore power, 14 volts with truck engine running. Tried emergency start and starting at the generator and starting with engine running. May be stuck at top dead center. Will check genset ground connection.
How do I get access and rotate piston past TDC if needed.
