PoorGary wrote:
Thanks and while I grounded the stereo better the lights remain 20 percent brighter. I do like the extra light.
MrWizard thats interesting what you say. I have limited knowledge off the converter. You say theres an AC ripple in the converters DC output. Thats good right?
Tomorrow Im just going to wire it directly to the block. A previous owner had a 12 volt line he snubbed off so I hooked up to that.
MrWizard is there a way to boost up my converter giving me that brighter light?
Or do I now qualify for the most dumbest question ever?
Thanks
AC Ripple is NOT a good thing on DC System.
That is why converters have filter capacitors to minimize the AC Ripple in the DC output.
AC (Alternating Current) Sine Wave is 'converted' to a DC (Direct Current) by taking both haves of AC Sine Wave (positive/negative) and making them into a Positive-voltage Direct Current
The smoother (less wave ie: ripple) the cleaner the DC Voltage will be.
DC Electronics (circuit boards for fridge, water heater, furnace----radios etc) do not tolerate AC Ripple
You can measure AC Ripple by using a multimeter set to AC Voltage and measuring DC Voltage------ preferably less than 1V AC on a 12V DC Circuit
