mkane's avatar
mkane
Over Air TV Antenna
I HAD a Signal Commander crank up TV antenna. I now need to replace it. My question is will the square tubes for a Winegard Sensar IV fit the roof mount for the Signal Commander or do I also have to replace the roof mount?
  • Try it you should, as Yoda would say. If you order from Amazon, no problem with returns.
  • wa8yxm's avatar
    wa8yxm
    You will not know till you try.. but Try I would suggest.
    Winegard Sensar IV and get a Sensar Pro for the indoor module (replace the one you have now).
  • They look VERY similar.
    Bet the tubes from Signal Commander could be used on Winegard or vice versa.
