Bernie_G
Jul 16, 2013Explorer
Overheating 2004 Tiffin allegro bus 36 OP cat. 3126 e 330 hp
Hello everyone.
I am new to this forum (actually any and all forums) I have just joined this forum this morning. I would appreciate any help I can get as I am at my witts end. I have a 2004, 36 OP allegro bus with a 330 hp, 3126 E cat. pusher with a side air inlet and hydraulic fan motor. The problem is that it is constantly overheating. I have spoken with Bob Tiffin 3 times while trying to get this problem resolved. I have been to Frieghtliner in Whiiter CA, La Mesa RV in San Bernardino, a local Tiffin repair facility "M&M Coach" that Mr. Tiffin sent me to in Ontario CA, and Johnson Power the Cat. dealer/representitive in San Bernardino CA.
It has had a new radiator installed, new surge tank and cap, new thermostates 2 of them as it takes 2 thermostats, all new belts and hoses, new fan blade etc.. It spent 4 days on the dyno at the cat facility (Johnsons Power) where they ran every test they could trying to find the problem while checking for proper operation of all of the engine cooling and operating systems including the ECU. They said they put 4 different programs into the engines control module/computer (evidently it had the wrong program in it?) before they were able to attain the best operating program for this coach.
Also, the gentleman that Mr. Tiffin sent me to at M&M Coach was the owner of M&M Coach must be recognized for his outstanding service that he gave me. He wanted to help me find the problem with this coach so he went for a ride with me so he could observe my driving habits/skills while towing my Jeep up and over Cajon pass in Ca. He also drove my coach up and down Cajon pass. The coach heated up at virtually the same place each and every time, it did not matter who was driving it. I have all the reciepts to show that I have paid for all of the repair work that I have had to do on this coach, with the exception of what M&M Coach did for Tiffin Motorhomes through their representative at M&M Coach in Ontario CA.. They did install an overheating kit they had, which included a fan shroud and parts that closed in this area of the coach to help the fan pull air through the radiator, as well as installing metal louvers in the engine compartment doors and cutting holes and installing expaned metal in the openings they cut in the back of the coach.
Bottom Line; Frieghtliner blames the coach builder, Cat. blames this guy and Tiffin says they have done as much as they can and basically every body just wants to point fingers. Just to be clear I am not trying to do anything more than get this coachs overheating prolems fixed as my wife really liked this coach. I purchased this coach in 2007 from a gentleman that was the second owner with between 12,000 to 15,000 miles on it so I guess you can say buyer beware. I am the third owner of this coach.
Can some one please help me with this, as I would really like to use the coach this year to go back into Colorado for my sisters 50th wedding anniversary. Again it is a 2004 36 OP allegro bus with a drivers side air inlet with side mounted radiators, hydraulic fan motor, 330 hp 3126 E Cat. motor. Thank you for your help and advice. Bernie G.
