AZCowboy's avatar
AZCowboy
Overheating when climbing hills
We are new to RVing. We purchased a 92 Fleetwood Bounder, 34 ft. It has a Cummings engine and Allison Transmission. It runs excellent EXCEPT for when climbing hills. The temperature gauge sits at 180 degrees until we start climbing and then depending upon the grade it can raise up to over 210 degrees. Within 5 minutes of pulling over, the temperature will drop back to 180 degrees and if we idle longer it will drop down to 160. We've replaced the thermostat, raidiator cap, had the radiator rebuilt, replaced all the hoses and fan belts. We also of course had all the radiator fluid replaced when we replaced the hoses and rebuilt the radiator.
Any other suggestions?
