atikovi's avatar
atikovi
Owners of P30 454 chassis, what are u setting the timing at?
Got a carburated '88 Southwind and I did a full service on it. New plugs, wires, cap, rotor, PCV valve, rebuilt the carb, new fuel filters, new fuel pumps. The spec calls for 4 before on the timing. When I checked it, it was at 16 before so I adjusted it to 4. Idle is set to 700 rpm in park and it's smooth. When I put it in gear the idle speed drops to where it's not smooth but if I adjust it to where it's smooth, it's too high in park. Could this be why the timing was so advanced. What do most of you set it at?
