udidwht's avatar
udidwht
P-30 series air bag info
With respect to ride height there is a lot of confusion it's measurement. The service manual states no mention of actual load only the rating of the axle. This will be in the motorhome (mine is on closet door 4880lb front axle).
When measuring the front you measure the distance between the upper control arm and the base of where the control arm bumper sits (iron to iron) ignore the rubber bumper. It must also be measured with the max psi from manual (mine is 50psi). Many have said to measure from the top of the bumper to the upper control arm. This is incorrect. It must also be perpendicular to the upper control arm when measuring.
Once measured that measurement is attained use it to compare in the service alignment graph to decide which degree setting is used when aligning the front.
Do not go over the recommended max psi for the front axle rating.
