Gjac's avatar
Gjac
Explorer III
Jul 24, 2016
Brakes dragging on a P-30 chassis
I noticed my driver side rear caliper was hotter than my other ones. I removed my wheels and cleaned the caliper slides and brakes with a wire wheel. I did both rears. Those dual tires got heavier over the last 10 years. All though some what better that rear side is still running hotter, so I assume the problem is the caliper piston not returning all the way. Have any of you removed the piston and cleaned it with success or just replaced the whole caliper? The brakes were last changed in 2007 by a shop but not sure if the calipers were replaced then.
