Octaneforce
Nov 16, 2022Explorer
Brian in Michigan wrote:
It seems that theres often 4 options for lower ball joints when you look for them;
Motorhome/stripped chassis with rear disc (part number 6511) *this is the correct one*
P30 standard van with rear disc (part number 6175)
P30 with rear drum (part number 6129)
F44 heavy duty chassis (part number 6117) *im not sure what truck these are for*
OK what would be the difference between the stripped chassis and the P-30 with rear disc?
Im not sure, its different part numbers so id have to assume chevy did something to change the front end for each application.
I assume the p30 with rear disc means a regular bread truck, and the stripped chassis got some minor change when they built them for rv manufacturers.
To be clear i only did this research as it applies to my 1993 model year, however it seems to be the same confusion for most of the 90’s
