Ok I'll bite.
Had a 1994 Fleetwood PaceArrow on the P30 with tbi 454
The thing wandered all over the place and changed lanes on its own.
A good front end alignment with some extra caster helps a lot.
I changed bell cranks to Henderson super steer,idler arm,steering dampener shock,larger ipd front sway bar with poly bushings front and rear,ditched the front coil spring bags and replaced with Henderson super steer coil springs,Henderson super steer rear trac bar,Koni shocks all around,Hankook tires,
After all that is still wandered. I finally fixed it.
by selling it and buying this
![](https://i.imgur.com/F93jrVfl.jpg)
