et2's avatar
et2
Painting under MH
I'm considering painting under the MH to prevent rust ( and fix what rust is there). So for those who have done this, what support have you used after the MH is raised to prevent it from coming back down while under it.? I have two jack stands but probably not that heavy duty. So if the MH is 28k to 29k I'd need 4 jack stands capable of 7000 - 8000 lbs? Or 6 at 5000? What do you do? Location should be along the chassis frame?
I'm assuming you use the hydraulic jacks on the MH to raise it ? I really dread doing this painting, but it needs to be done. I haven't inquired into having someone else do it, but I'm sure it won't be cheap. Camping world in Belleville MI. has a body that will do it, I guess I can get a estimate from them first.
