JamesWillard
Dec 10, 2017Explorer
Palazzo Not Charging from Engine Alternator
Just picked up my 2013 Thor Palazzo from LazyDays last week. All the way home and since, the Control Panel CHARGER will not turn on with engine running. Normal with Shore Power and Generator. Use/Store switch is good. Replaced the BIRD and Trombetta - No help. Noticed that the Trombetta is ALWAYS energized. When I disconnect the "RELAY" wire at the BIRD, the Trombetta de-energizes. Control Panel CHARGE will never come on with Engine Alternator, no matter the status of the Trombetta Contactor. With the BIRD out of the circuit, the Aux Start switch energizes the Trombetta normally. Still no CHARGE at the control panel with engine running. Chassis batteries charge normally.
Help!!
Help!!
