JackMS
Aug 31, 2015Explorer
Penguin A/C compressor locked up
Last winter while exercising my a/c's in heat pump mode, the front one would kill the generator when the compressor came on. Fan ran fine. Due to some issues I haven't been able to get to work on it until now. I turned a/c on while on generator and watched EMS. when it tried to start the compressor, it showed 53 amps for a second and then went back to around 5 amps. Fan was still running but compressor was not. So I figure the compressor is locked up, so I just want to replace the whole unit.
Have been reading a lot on here about this. The bad unit is a 2007 and the bedroom unit is a 2005 and it works fine. I have 1 5-button thermostat controlling both and the furnace. If I put a new penguin in the front and get the 12 to 5 button convertor, will my rear unit still work right?
The other idea is to put in a brisk air. I added a third unit a while back and it is a brisk air. Height is not an issue as my satellite dish is the tallest item on roof. But would a brisk air work with the penguin in the rear or would this require anything extra? Just considering this route because the brisk airs seem a good bit cheaper and mine seems to move more air than the penguins.
Gonna call to order something soon but would like to be a little more knowledgeable when I do. Thanks in advance
