brewer60's avatar
brewer60
Power Gear leveling panel does not come on
I have a 2004 National Sea Breeze LX. When I tried to level the motorhome the control panel would not come on. It worked great the last time I used it. I checked all of the breakers and found no problems. Any ideas what might be wrong?
  • Ignition switch on....transmission in park....parking brake engaged(with dash indicator confirming)? Mine will not work otherwise.
  • I believe you have a freighliner chassis. There are fuses located close to the battery disconnect relay in the passenger rear of the coach that you should check. Sorry I can't get more specific on their locations.
  • Are other things working in the coach? Any 12v fuses and not breakers?
  • Did you remember to have your key in with power on? Main control panel outside may have a breaker/fuse. Ours is under drivers seat area inside the front bay.
