I have a 2011 Winnebago and got it out of storage April 1st. I installed batters and drove it home and all was good.We had bad storms and lots of lighting of strikes I unplugrd my my 15 amp cord but left it pluged to the camper.A few days latter I went in and my big tv would not work . I tried my 1000 watt inverter and the tv work. I got my wife,s cell phone to see on charger and found some of the out let worked and some did not. I started my Gen set and turned off the inverter the tv and most of the out lets work I have it dow to two out lets not working. I called Winnebago and said my slide under the slid they said a wireing out under my dinette and said that under slide might be a bad wire or in the box where all the wires come into the coach.I have reset all my out lets with trips in the middle all of them tripped so I think it hit the ground and some how It tripped all my breaker and the inverter had tripped also. I had a side slab by or drive way so how did it trip my breakers. Also my cruse control Worked last fall on the way home from the grandstand it would not work. I called Winnebago and they said they put there fuse box in the place of Fords. So I called Ford and they said the put it under the hood some where. If any body can help me or give me some advice that would be great
