supercub's avatar
supercub
Pro-Fill RV Edition Dual 6-Volt Battery Watering System
The motor home I recently bought has a Pro Fill system installed on the 4 house batteries. I filled the batteries today using it......seemed to work well. I'm just curious if anyone has had problems with this system or are they pretty much full proof. Thanks
Brian
  • Well,that is the benefit. My battery tray doesn't slide out, so to fill them meant first taking all the tops off, then trying to top them off without much room above them. The NAPA battery filler didn't work; it never filled properly so I used a small funnel and spilled water everywhere. Then I had to wedge my head in the space with a flashlight to check the level. Usually either under or over filling them.
    Bottom line was it was such a pain I rarely did it.
    Now I connect the hose to the pump, stick the hose into a gallon of distilled water, pump a half dozen times and I'm done. Plus, as stated, they don't evaporate off as much.
  • Yes. It was fairly difficult to top off the batteries without it. I want to get a good, long life out of the batteries so I hope it will be worth it.
  • Had our Pro-Fill installed Jan 2006 still works great, cost back then was $175.00 for a 6 battery bank.
  • The only problem I have had is that the bulb cracked and squirted water out after 3-4 years. You can buy replacement hose and bulbs online for about $20. I couldnt find just the bulb. Had to buy the hose, check valve and bulb complete.
  • I used that system on two boats I had and on my previous motorhome. They worked fine. Just make sure you don't squeeze the bulb to add water until after you are sure the batteries are at full charge.
    Have AGM's on current coach so don't need it now.
  • I've used one for years. Works just fine. About once a year, I remove the system, give it a good look over and reinstall it. Each time I've done so, the battery electrolyte was where it should be
    Ed
